67 coupe window trim removal
JeffTepper
OK, I've done windshields and fastback rear glass but I have not had the opportunity to remove the upper and lower trim strips on the back window of a '67 coupe. The left and ride sides are easy enough to figure out....(screws!!) For those of you out there with actual experience/knowledge, what's the best way to remove the top and bottom pieces of window trim?
TIA for your suggestions.
yes they do, if you have one of those goofy looking flat tools with a hook on it you can get them to let go. The top trim isn't too bad but the bottom one will bend real easily!
My memory is the bottom is extremely fragile and it is best to remove the others take out the glass, then cut away the gasket to get it loose. The top has clips and isn't too bad. Becareful with these, not reproduced.
