1965 window run replacement
Horseplay
I Don't Care. Do you?
Thinking of replacing the window runs. Those are the long window guides at the rear of the wing assemblies. Guide the main window. Near as I can tell no one sells replacement material for inside the channels. Just the channel with new "felt" installed.
https://www.npdlink.com/store/products/21538_9_1A-103777-494.html
My question is how does one know they need or will benefit with new ones? My glass has a good amount of play inside the channel so I am thinking the material has been worn away over the years. When I shut the door the glass kind of "rattles" around a bit no matter how I adjust the angle of the wing/guide.
Insight anyone?
Terry, have you tried to adjust the rear guide to put a little pressure on the rear part of the window. That might keep it from rattling.
I can take another look at it. When the window is up though there is not much there to work with. That channel up front has like 1/8" worth of slop. Pretty sure that is the bulk of my issue.
Nope. Those are both seal items for the wing. I actually have those on the shelf ready to go on. The stuff I was searching for is in the long channel that runs down deep into the door. At this point I'm pretty sure it is not sold alone. I will pull my door apart here pretty soon and get a look at what is used in that channel. At that point I will either come up with something that can be used or just buy a set of the replacement channels.
I should have just rebuilt the damn wings when I had everything out long ago but they looked pretty good and figured I could wait until I got the frames re-chromed some day in the future. It is pretty much the only damn thing I didn't re-do or buy new on the whole car! Lesson learned.
IIRC there is a "cushion" that pushes to the side of the window on the rear run channel.
Correct me if i am wrong.
