SELLERSRODSHOP
i finally got around to finishing up my homemade shaker unit & thought you all might want to see how one can be done for less than $200. i'm cheap & couldn't swallow $895 + for a repop or original so decided to build one to my styling tastes based on the original air cleaner assy & a torino snorkel.
i started by smoothing over the original inlet & oil breather tube. next step was to cut the center out of the lid & reform the edge to fit the air filter.
i added a shorter air filter than the one pictured for clearance, then used the leftover outer ring for the basis of the midplate. i reformed the ring in a planishing hammer to give it a sharper vertical turn for clearance over the filter unit & fabbed up a plate from 16 ga flat sheet steel for the snorkel mount. i then added 4 tabs on the lid & matching ones on the can to fasten the unit together.
next, i mounted the snorkel & gasket to the midplate. i used a threaded tab welded under the plate for the 1/4-20 screw in the center & the rear gets 2 holes drilled in the squared off section of the midplate to bolt down the rear of the snorkel.
after i fitted the unit to the car & measured/cut the hole in the hood, i had to make a custom trim ring to fit the mustang hood.
after all the fabrication & fitting
finally got around to finishing the paintwork this week. this is the custom blue pearl that i'm using on the car. the snorkel is black basecoat with PPG 2060 pre flattened clearcoat.
