So just a few additional comments.
I used epowersteering which is about 1000$ cheaper then EPAs
https://epasperformance.com/collections/all-products
http://www.epowersteering.com/purchase/product/auto-eps-controller-saturn-vue-chevy-equinox-units/
However like I mentioned it’s a lot of work. Making sure everything is clocked just right and lengths of the steering rods need to be right.
The EPAs is different when Driving. When you make a tight turn, normally, when you straighten out the wheel, it will spin back to near straight, but not with EPAs. You have to turn it back. No big deal but it is different.
If I was to do it over again I would. This thing is really amazing.
Now for the rack: I purchased the Manual Unisteer Rack. It’s a good solid rack. You will have to grind certain areas of the rack and cross member areas to make it fit. But it is very solid and it works. It’s truly a 4 complete revolution rack from stop to stop. Better then what I had but I do wish now it was less revolutions. But it was 1k compared to 1600 I think for TCP. Now the rack is solid zero play and works as advertised. I have seen older reviews about how they are junky. To me it is not. Again very solid and works as advertised!
Also when I first started working on my suspension over a year ago someone told me to get an alignment tool, so you can do your own alignment. It’s not that hard and I’m glad I listened. In the past year and a half, replacing all these suspension and steering parts, I think I have done over 10 alignments on my stang. Lol.
