I’ll let you buy that for me.IMHO, what do you need?
One of these: https://www.johnbean.com/us/wheel-alignment-machines/?utm_term=auto repair shop&utm_campaign=JB_Tru_Point_Toyota_LG+(JAN_2026)&utm_source=adwords&utm_medium=ppc&hsa_acc=5681953760&hsa_cam=23505514531&hsa_grp=193811671844&hsa_ad=794576627978&hsa_src=g&hsa_tgt=kwd-297887730621&hsa_kw=auto repair shop&hsa_mt=b&hsa_net=adwords&hsa_ver=3&gad_source=1&gad_campaignid=23505514531&gbraid=0AAAABA9UQieRHEaQIlCS55MgE4X47qRx4&gclid=CjwKCAjwyabTBhBFEiwAM3mNUAu4EJTKCzFRn_kIRN2kSlnFB4Jop4sVig0OXYxCTWjbWN6wepZjSRoCoJsQAvD_BwE
...and these specs:
It's my belief that "optical" or "bubble" gauges are not accurate enough, nor do they provide a reading of Steering Axis Inclination needed to insure that the steering knuckle/spindle is not bent. I go by the old adage... "Close only counts in horseshoes and hand grenades".
You’re lucky? as you have steel wheels and mine are Al You Mini UmI just stick it on the flat part of my SS wheel snout
I "hover" over the alignment tech at my local Midas.... I think he appreciates me after I showed him how to adjust caster/camber on Chrysler LX chassis....I’ll let you buy that for me.
I’d rather be close than have the incompetence that is around here at alignment shops and then I can only blame myself.
Chris
One question.... How do you adjust for wheel "runout" when using these adapters?Just get the whole enchilada! That was my mantra before stuff happened, and I had to retire.
The method I mentioned previously is the most accurate though. It was right on when my friend Nick checked it at the Audi dealership he works at. It is not rocket science. Might I suggest you stop by an autocross event, before it starts or during a break, and ask around on who they have doing there alignments. There is usually "a guy" or shop that will be recommended.
You don’t. I did alignment’s for a living 45 years ago and no you can’t tune out wheel runout like with the “real” alignment machines. Most modern aluminum wheels are machined well and what are the chances the kid at the tire store bothers to adjust the runout before doing the alignment?One question.... How do you adjust for wheel "runout" when using these adapters?
"Bubbles" and "scrub gauges".How did they do alignments back before optical equipment and lasers?
