crustycurmudgeon
I ordered a set of reproduction black license plates from a German vendor on eBay for my '67. I decided to pull the trigger and see how they match up to the originals. These plates are soooooo close to the originals as to be essentially indistinguishable. They're the same gauge of steel as the originals. There are a few "tells" if you compare side by side--the distance between the U and X, for example, is slightly different. The finish is glossier than original so they wouldn't pass for original unrestored, but the colors are spot-on. The dimensions, the weight, even the 63 in the corner are spot-on. The seller even gave the option of 63 with or without the apostrophe--they were originally made both ways. These are a vast improvement over the plastic coated aluminum repros I bought several years ago. Bottom line--NO ONE will be able to tell these are reproduction plates. Even me.
