OK, I'll admit stupidity on the LS design. Enlighten me. What is so earth shatteringly different than say a Coyote? Obviously they can be had in large cube variety. Is that the biggest thing?
I have the LS1 in my Vette that gives sophisticated power- it isn't noisy, and doesn't lope. It doesn't have huge CIs; the LS1 has 346CI, but some versions of the LS go up to 427. A stock LS7 will produce 505hp, and the supercharged LS9 gives 638hp from the factory.
This is from Hot Rodders Forum:
-all aluminum
-6 bolt mains
-better oiling systems
-improved power peak
-higher redline, especially LS7, it has been tested to 8000rpm, but doesn’t make power after about 7000
Distributorless, coil-near-plug ignition system
The LS
engine will make the same power as the old SBC but will do it with a lot less cam. Comparisons show the LS engine will make the same power and do it with 4 or 5 more in hg of
idle vacuum.
The big thing is technology. The computer-aided casting design is so much stronger. A completely stock LS1 bottom end is very capable of giving 100k or more reliability at 600 hp. That same level of reliability in a traditional SBC is more like the 350-400hp mark at best. 200k is normal for an LS in a C5 Vette.
The heads use a very different type of
intake port that flows much more without sacrificing velocity and therefore torque and drivability. The quality of
head flow is what makes such excellent power.
They also not only use those wonderful 6-bolt mains, but they incorporate a stiff
cast aluminum oil pan that further stiffens the crankcase.
