He's putting in a cam from a Prius...yup...a completely different new car for sure!
Well the car has been pretty mild. I wanted to wake it up a bit. I've only been running 13's in the quarter. I'm putting in a more aggressive cam. I'm going to break it in with the old valve springs which have seemed to gotten weaker since I first built the engine 18 years ago. It floats the valves at 5500 rpm and used to rev over 6K. Anyway, after the cam is broke in I will pull the engine and trans. I have aluminum heads, roller rockers, etc. I also have a TKO 600 5 speed to swap out the C6. The swap requires different motor mounts that move the engine back and lower. So I figured I'd pull the whole thing, swap motor mounts, heads and trans. That gives me room to put in the hydraulic clutch too. So it will indeed be a different carYou are a busy bee !!!
Whats the plan ?
after the cam is broke in. hopefully in a month or so. I have to go to Australia in two weeks for two weeks.Pics of that new transmission. So when do you plan to install the transmission?
you are right! I have had this car 27 years now. Spent a lot of time and money. Most of the spending has been as I have gotten older. But it has served as a family teaching tool, a way to spend quality time with my family and friends and has become more than just a car.Craig......we all live once......so we can afford to be a little crazy when it comes to mustangs. don't we ?![]()
