Patrick Stapler
Gotcha. Same result either way. I would prefer less shims...up to you. I have no shims at all on my rear UCA bolts. I do camber adjustment via the camber kit on the LCA.
Turn plates aren't necessary. I did mine on nothing more than a smooth concrete floor. Key being to block the rear wheels so the car doesn't move as you turn the front wheels. Lots of people lay down a couple sheets of plastic under the tires, some even adding a bit of a lubricant between sheets.
Good point Terry. I use a couple of 12" linoleum tile squares sprayed with WD40 under the front tires. I can turn the front wheels with my pinky finger.
Okay. I order the alignment tool!! I think I will know about my front suspension pretty good when it's all said and done. Lol. I'll keep you guys posted if in run into any issues. Slim chance I might be able to finish the right side if the parts come in early next week.
Gross adjustments. If it were me...and it isn't, I would remove them all and see where you are as a baseline. Since your car has the LCA camber adjustment, I would think you would only need shims for gross caster adjustment. Then use the adjustable struts for fine adjustment. I got lucky on my car, it is dead even on both sides. I have a 3/16" shim pack on the front UCA bolt and the #2 camber plate on the LCA. That got me to -1.5 camber and +3.5 caster. I added another 1/2 degree caster with the struts and ended up at -1 camber and +4 caster.
What alignment tool did you get? If you got the FasTrax unit you can get these separate and they lock it on very positively vs. just pressed against the wheel surface.
https://www.amazon.com/Specialty-Pr...rd_wg=Zo0KN&psc=1&refRID=0CYVPX6MQT6NPNCPQSYC
Yep, just jack up the car to get the wheel off the ground and loosen up the UCA nuts. Pulling the arm out enough to get shims in and out can be a challenge as the force of the coil spring keeps it held firmly in place. If you can't get it to move enough with some good old muscular yanks by hand a pry bar can make it possible. Once you get the feel for it it seems to get easier.
At this point, I agree you should probably pull out all the shims and start fresh. Those lip adapters work great. I suggest you buy a set. That way you can lock it on and keep it in place when turning the wheel to measure caster.
If you have equal shims stacks on both bolts, removing them all will put you right back where you started in terms of caster. You'll gain negative camber. Depending on how all measures out you can add shims equally or favoring one bolt or the other to reduce negative camber and tweak your caster.
Okay great, I think that's a good recommendation, I will remove all shims. Good news is that with this spring I can muscle it in and out of the spring perch without a spring compressor. The hardest thing was actually getting to the bolts. The 351w is a tad wide. Interesting that it didn't drop as much as I thought it would. Haven't done the left side yet, but it sure is driving pretty smooth.
Going to Yellowstone next week so I won't be on here much but please stay tuned when I get back and back to work on the beast. I may need more help. Thank you!
