Was going to use an external mounted fuel pump on my new engine build so I got this to feed it. Plans changed and am going to try an in-tank set-up. They list for $169 new. Make an offer. Thanks.
Mark
Applications:
1964-1968 Ford Mustang
1960-1965 Falcon (except station wagon, Ranchero and Delivery)
1960-1963 Mercury Comet
1967-1968 Cougar
Specifications:
Drop-in replacement for factory 5/16" or 3/8" sending units
Budget alternative to a fuel cell or weld-on sump
Perfect for all cars with an electric fuel pump and return/bypass style regulator
1/2" pickup tube reduces flow restriction to suction side of fuel pump
1/2" return tube allows use of a return/bypass regulator without modifying the fuel tank
Billet aluminum base and aluminum tubes are anodized for use with gasoline or alcohol
Stainless fuel level sending unit works with OEM fuel level gauges (78-10 ohm)
Mark
Applications:
1967-1968 Cougar
Specifications:
