I've been thinking that I should work on adding one of these to my shop.
Any chance you can provide some measurements..
Base frame dimensions
Stand/upright base dimensions
Most Frame Charts (like the one I attached) do not show bolt sizes or locations, they are based off the bottom of the car 'frame' rails.
So I'm wondering if a person who is building their own should support the vehicle on the areas that are described on the chart to determine the final locations for the locations used on the German jig.
The "german" jig supports the car on the following places :
- front strut rod mounting holes
- lower control arm mounting holes
- upper shock tower caps mounting holes
- transmission brace mounting holes
- front mounting holes of rear springs
- shackles mounting holes in rear frame
Or wouldn't that be accurate enough?
