Shaun
For those that have done this, I have a few questions as my 66 coupe is currently under the knife getting stiffened.
Did you seperate the inner rocker and only use the 'U' shaped channel piece? The outer rocker already has the flat plate that the floor used to be spot welded too. Do I use the additional flate plate that came spot welded on the inner rockers and plug weld that to the flat plate of the stock outer rocker making 2 flat plates?
What did you guys do about the additional flange on the inner rocker? The outer rocker already has one. Do I cut it off?
