Shaun
So I just put together a kit for the 68-73 Mustang disk spindle using SN95 calipers, modified anchors, 65-73 5-lug drum hubs and the 13" high hat offset rotor I use:
Link
Seeing as how the Granada spindle is not that much different, this kit will also fit those spindles. Just the upper bracket hole will need to be drilled out in the spindle from 1/2" to 9/16ths.
Putting this kit together got me thinking. Lots of people like my Cobra brackets for drum spindles. Who would be interested in the same concept for 68-73 Mustang DISK and Granada/Versailles spindles? I often get asked at the shows I do what I have for the Granada spindle. Folks can be funny sometimes though, sure they are interested until they hear the price. I want to be upfront about the estimated cost before even pursuing it. I don't want to end up with a lot of money tied up in a pile of slow moving brackets! I'm sure you can appreciate that. :thumbsup:
I figured I'd ask here and get some rough numbers first.
The kit would use a similar bracket to the one pictured above, just the offset would be different to accomodate the shallower hat of the Cobra rotor. The kit above and my planned kit for the Cobra rotor will use a modified anchor (the yellow zinc piece). I'm estimating a selling price for the SN95 Cobra rotor bracket kit of around $299. This would get you the spindle mounting brackets, modified caliper anchors, hub-centric adapter shims and install hardware. Just like the kit for the drum spindle, you'd need to add calipers, pads, hubs, bearings, seals, hoses etc.
April 23rd, 2009
I've been working away on this project and just finalized the engineering.
As usual we way over enginered the product. We plugged in a 3800lb car with 275/45/17 rubber pulling 1.2G's decel with 80% of the braking being provided by the front wheels. As you can see these figures are very generous for the average vintage Mustang. We still acheived a safety factor of almost 2:1.
The longer bosses don't create an issue so I'm ready to start manufacturing. I still put the retail price at approx. $299 for the brackets, modified Cobra anchors, bolts etc. and rotor centering shims. Is this too much money? Should I not bother? Who is interested?
Link
April 23rd, 2009
