Shaun
A good customer of mine over in France was complaining about the Porsche's in his vintage racing group out-braking him. He has been using the stock 65-66 Kelsey Hayes 4 piston brakes. He needs to stick to 15" wheels to be legal but wanted more brake.
I decided to have a go at building the uber giant Boss 302 Trans-Am system for him. They used a 11" something rotor from a Lincoln pressed onto a drum hub and a 67 Tbird caliper. I'm using the same caliper but went with a 2pc 12" x 1.25" rotor mounted to an aluminum hat. This weighs a few pounds less than the all iron version. I'm supplying him with some Porterfield R4 pads for the track.
I'm pretty geeked that it all turned out ok. I'm even more amazed it actually fits inside a 15x7 Torqe Thrust D!
Waddaya think?
On the left is the base rotor in the 11.25" kit, right is the 12" mofo. The aluminum hat really helps save weight. The 12" rotor complete with hub and studs weighs 3lbs LESS than the smaller 11.25" rotor with integral hub/studs.
Thanks to all the forum guys and vintage racers that helped me out with this project!
Waddaya think?
