It did come dangerously close to you though when it was pulled home. That proximity alone could have had something to do with this.I have not touched that engine.
As often says, I'm an idiot. There was nothing wrong with the engine. Since I don't remember being high on crack that day my best guess is I didn't have the truck in neutral as I thought and the resistance I felt manually turning the crank was the"slop" running out of the drive train. Seeing as how I rolled it around that day not sure how that could be but anyway. The crank must have some serious amount of dwell occur at the bottom/top of the stroke because in a good degree of rotation that damn piston didn't move! That or maybe I was high on crack. Hard to tell. Out of the truck it spun free as a bird.So what was wrong with #1 cylinder?
More accurately, it will be an air suspension not necessarily "bagged" in the general sense of the term. "Bagged" would infer the use of basic air bags and shocks at each wheel. While not 100% locked in, I am leaning toward using Shockwave units. For those that don't know, Shockwaves are a unit that combines a shock and air bag in one. While much cleaner in terms of simple set-up and installation, they are PRICEY. To the tune of 4 times the cost or more of say a standard double-convoluted bag and separate shock. Still working it all out in my mind. While not intended to be a real performance build I still wouldn't mind getting the best handling I can out of it. A separate shock set-up might actually make a difference. Have to research more.It's going to be bagged?
Sure let me potentially waste all that cash!
The limiting factor with the Shockwaves is the available adjustment. It's only realistically a couple inches max (bag portion) from what I have found. So if you want to really "slam" something for show and then pump it up enough to drive home they may not work depending on all the other components and how you have it all set up. With a big fendered old ride you have a better chance of making it work with all that room for the tires. I'm going to put mine all together (sans bags) and see how things look before I decide.
