Voltage regulator wiring
Grabber70Mach
I'm working on a friends 69 Coupe, a yellow wire has came off of the voltage regulator, also the wire that goes to the radio noise suppressor came off. Do both of these go to the third terminal down from the top of the voltage regulator? Do you have the female spade connectors that slide up in the connector available? If so how much with shipping to MD are they?
Yup, so long as you have a crimper that can handle two wires and crimps both the copper strands and the wire insulation separately. It's probably easier and better that I send you a used set...simply splice it into the yellow wire from the harness.
Cost? $2.00 plus $1.00 shipping. PM me for details.
