crustycurmudgeon
I'm preparing my T5 bellhousing for the spacer block installation and I ran across the following issue:
The top edge of the ruler is centered on the pivot ball boss and is parallel to the marks I made marking the edge of the clutch fork opening, and is also centered in the center hole. This places the ruler slightly left of the center of the clutch fork opening. Should I not use this measurement when placing the spacer block? Placing it centered in the opening, as the instructions advise, would appear to place it off a bit to the right (about 1/8 to 3/16").
Frank
Frank
