A
Anonymous
Guest
I have had a small leak that is dripping from the scatter shield since the car had been completed on the Blue Twin turbo car. I first thought it was the rear main seal so I replaced it but seen no improvement, its a 2 piece seal. Upon removal, the old seal (which was new) showed no nick or crack or scuff that would indicate a leak area and it was offset with silicone sealing the mating surfaces. Upon futher examination the front side of the flywheel is dry but there seems to be some oil on the clutch side. Also there is a puddle of oil in the bottom of the scatter shield. I was able to see the top of the intake and valve covers and they are dry and dusty and replaced the oil pan and gasket and it appears it's not there. All ideas welcome as this seems to be a weird one. Oh, the leak seems to be much worse under boost as I can smell oil burn where it is hitting the headers.
