LastDeadLast
Hey guys and gals,
I've got a delima.. the next phase of the project is to install the fuel lines for the fuel injection. I bought a nylon fuel line kit from Ron Morris which (hopefully) contains enough line to run both the supply and return lines.
What I'm struggling with is how to get it connected to the fuel tank, which has -6AN connectors on both the supply and return lines that come out of the top of the gas tank in the trunk. In the pic below, you can see where the supply and return fittings screw in in the center of the tank (covered with green tape):
My thought is to run braided lines with AN fittings from the tank and out the trunk floor on the passengers side. Then transition to the nylon lines once I'm outside the truck and then up to the engine.
My question is how to I transition from AN fittings to nylon? I have no clue.
Thanks in advance,
-Shannon
Thanks in advance,
-Shannon
