I am fed up with Petronixcrap! I mentioned a while back about the P2 going bad after about 6 years or so and just ordered a P1 to replace it. That lasted all of 1 day. I called Summit Racing and sent it back and they sent a new one. I installed it and danged if it didn't go to crap! I am using the 1.5 ohm coil that I got back in Nov. with the first P1 that went to s*it. It is the correct coil to use. I checked to make sure it was not getting any voltage when the ignition is off so it would not burn up like the P1 is known for doing. WTF is going on here. I am using a full 12v to the ignition (no resistor wire). I am going to order http://www.summitracing.com/parts/SUM-850023/?rtype=10 if it will work ok with the '90 5.0 HO. It says a hardened steel drive gear so I assume it will work with the roller cam? What say ya'll? Thanks, Gary.
