kb3
I am installing a 93 5.0 in my son's fastback. The books call for a "min starter". This appears to have a starter solenoid mounted on the starter. Is there any reason to still have the fender mounted solenoid? Several diagrams show bypassing the fender unit for the hot wire and only using it as a trigger wire. I don't see why you couldn't use the wire from the ignition switch directly to the starter, unless the current pull was too much. any ideas?
also...I am installing an entirely new American Autowire wiring harness, so everything is new.
Thanks!
Thanks!
