sigtauenus
As you know, my shakedown drive on my fastback has been driving back and forth to a MCA show here in VA Beach this weekend, roughly 8 miles one way from the house.
Today as I was pulling into the show I felt a tug on the steering as I was parking but thought it was a pothole in the crappy mall parking lot. This afternoon when went to leave, and I'm not sure why I thought to do this, but I leaned down and looked at my power steering header drop bracket and it had pulled loose from the frame. One of those T-nuts was still attached to the bolt but no longer in the frame.
I just did a search on Google for "mustang power steering bracket fix." The number one Google hit took me to an old VMF post where JohnPro gave the permanent fix:
You may have something else that caused it. Ripping that bracket off the frame should NOT have any effect on how the car handles, or have it "going all over the road". It will just mean that you immediately go to manual steering. I've been there, done that, twice in my daughter's car. First time it ripped off, the second time it snapped off and the base of the "drop bracket" remained attached to the frame.
The way I fixed this on my daughter's car was a royal PIA, but it will never happen again. There's a hole up above in the frame rail. I dropped grade 8 washers and bolts down through that hole and fished them out through the frame rails using magnets. The only way for her bracket to rip off again will be for the grade 8 bolts to fail or to rip GAPING holes in the frame rail. It was an all day project to do this, though.
Two things come out of this post. First off, although it may sound bad, its not catastrophic when it happens. I can still drive the car if I have to (won't, but if it happened on the highway or whatnot, I could move it to a safe location). Second, it provides the permanent fix without doing the drastic welding of the bracket to the frame.
I have no doubt that this is not an isolated incident. I will Google something 10 years from now and a JohnPro answer will help me.
Thanks John!
Edit: Not sure if this would help or not, but perhaps we could have a sticky topic of stories along the lines of "JohnPro helped me today." Might be neat for Tracey and those here who were good friends with John to see how his contributions continue to help people with their cars.
Thanks John!
