Gigantopithecus
So I pulled the brake pedal assembly the other day, and noticed this:
Looks like some backyard engineering to me.
"AzPete" said:Yep....I think I would be doing a bit of work on that one. Maybe compare to the correct unit so you know where things are wrong at....
"AzPete" said:Been there.....done that..... Some things can really scare you. Loose bolts, parts not replaced and said they were, wire nuts on electrical, missing parts under others, poor prep for painting, Great Stuff in the cowl, and on and on and on......
At least you can spot the bad areas when you find them. I would be looking at all the safety items to make sure they are up to standards, then go after the rest.
"AzPete" said:Mechanical brakes.......drag your feet thru the rusted holes in the floor.....
Way back in the olden days cars had mechanical brakes....a rod actuated them instead of fluid....real safe.
"Kats66Pny" said:Pfft.. Welding.
If ya can't duct it..... :roll LOL
"Fast68back" said:Wait, you have a Mustang AND you work on it? When did all this happen?
"Gigantopithecus" said:Seriously though, I really don't spend as much time on it as I should. Most of what I need to do will require money, something of which I'm lacking.
"monkeystash" said:Ha, just wait until the baby comes! You'll have no time and no money!
