Holley Carb
Aussie67
I am currently running a 600 cfm holley on a close to stock 302.
I know they work ok but what are the collective thoughts of changing down to 500, 2 barrel?
First off, why the need to change? Is it a dog with a 600? If really interested to try one, do it on a dyno so you know what the difference ends up being.
Going from a 600 4 barrel to a 500 2 barrel what are you hoping to see? You'll get better daily driver economy out of the 4 barrel and provided it is jetted and set up right you'll likely see more seat of the pants fun with it too. I fail to see any benefit changing to a slightly lower CFM 2 barrel.
I absolutely agree. The primary 2 barrels of the 4 barrel carb is more fuel efficient than the 2 barrel carb. If you think it is too much, why not go to the 480 cfm version (Autolite 4100) that was used in all A code Mustangs and is an excellent carb. The Summit version that is quite popular is based on the 4100 design.
OK, so I'll keep the 600 and put a recon kit through it. Its running but dies/ struggles on acceleration. Wanted to check the general thinking before going kit or new.
What you're describing is likely carb related and a good cleaning alone could fix it but doing a standard rebuild wouldn't hurt either. Be sure to check your incoming fuel line and filter as well. It could simply be a low or inconsistent fuel pressure issue too. If you don't have a fuel pressure gauge in place by the carb, now would be a great time to add one.
