Don't kick me...but this is on my son's 350 cheby (in the '56 in the pic by the stang). It did wipe a couple of lobes as I have everything apart. I looked up the valve spring pressure for the comp cam springs and they are a whopping 432 lbs. :wtf This was a higher lift cam, but not a monster. Just a slight lope at idle. Should I put the oem springs back in (that I still have) to use with the new camshaft or just reuse the monster springs (Valve Springs, Single, 1.255 in. Outside Diameter, 432 lbs./in. Rate, 1.153 in. Coil Bind Height, Set of 16).
New Camshaft is Hydraulic Flat Tappet, Advertised Duration 266/266, Lift .440/.440
Need some of you experts' opinion/help please :bowdown
