toddwallace
I am still struggling with my '66 shutting off under acceleration. A little background..
1966 Hipo 289 w/ SN-92 Paxton
Holley 650 DP
Mechanical Fuel Pump
MSD Digital 6 ignition
MSD 31323 wires
MSD 8253 coil
MSD 8579 Distributor
The car starts and idles fine.. It sat idling for our an hour w/out die'ing. You you can wrap on the accelator as much as you want and it is fine. At very low RPM's in first and second it is fine, but puch it and it cuts completely off. It will start right back up from turning the ignition, but does not seem to start itself from pop'ing the clutch. In third under heavy acceleration, it cuts out, but does not shut off. In fourth, it run fine up to speed. Fuel pressure reads around 6 -7 lbs and does not drop.
I thought it might be a grounding problem on the MSD, so I rechecked all that. I replaced the CAP and Rotor because I had one.. I do notice a bit of a fuel smell..
Dallas Mustang thought it was a spring issue in the distributor allowing it to over advance, but the springs all look fine
Any thoughts
Holley 650 DP
MSD 31323 wires
MSD 8253 coil
Any thoughts
