Distribution blocks
jims6t6
What year, & model cars should I look at getting a distribution block for use with Kelsey Hayes front disk and a 67 Mustang dual Master Cylinder to put on a 65?
I'm using the OE-style combo valve I got with my KH-style CSRP kit. I believe it's designed for 68's.
What I do is run the rear bowl of the MC to a T and then to the front brakes. The front bowl goes to an adjustable prop. valve and to the rear brakes.
I kept my original 65 distribution block, and plugged the outlet to the rear line. The brake line goes from the m/c to the prop. valve and then directly to the rear line. No change for the front lines.
I recently finished my V8 front disc to drum swap. Feel free PM me with any specific questions.
Re: Re: Distribution blocks
"DEL65" said:
I kept my original distribution block, and plugged the outlet to the rear line. The brake line goes from the m/c to the prop. valve and then directly to the rear line. No change for the front lines.
That is what I did also.
Sent from my HTC Liberty using Tapatalk
