Carb setup info
Discussion in 'Engine and Drivetrain/Mechanical' started by B67FSTB, Jan 8, 2019.
  1. B67FSTB
    So , I had bought a 351W engine in the past and meanwhile I made a teststand to runtest the engine.
    The engine has a ACCELL distributor and the cap sits high so I have to rise the carb with a 1/2 spacer. So far so good.
    What do I have : edelbrock 2181 intake which is a 4-bbl Square-Bore Carb Flange.
    edelbrock 1405 600cfm carb
    My questions : Can I use this kind of spacer ? I have a phenolic one ?
    how does the upper and lower seals look like ? Thx !
    [​IMG]
  2. janschutz
    janschutz Corn Hauler
    that looks tall. With the extra height of the 351W, you do not have much clearance for the air cleaner. I only have about 3/8" of clearance left on mine setup.
  3. B67FSTB
    Thats an example. Its a 1/2 spacer with the 4 holes.
    And the engine is on a teststand but it should work in a 67 engine bay.
    Just wondering which gaskets to use beneath and above the spacer.
  4. tarafied1
    tarafied1 Well-Known Member
    I just use regular stock type gaskets on my spacer
