Linux Mint 11 Rulez....
First of all, cover the dist. and carb with plastic bags and wash the engine and all surrounding areas. After it is dry, get on line and find the wiring and hose routing diagrams for your setup. Fix those so they look nice. Then, maybe look at doing a painting as mentioned.
Looks like you are missing a vacuum line to the PCV valve on the rear of the passenger side valve cover. Is there a matching opening in the rear area of the carb? If so...big vac. leak.
WOW that looks nice! any pics of how you ran the wires (an up skirt shot)?
