I needed a shoehorn but it is pretty tidy IMO.
I added polished stainless steel hardware, and polished aluminum parts. Moved the Horn to under the driver's fender and covered the grill opening. Now I am removing or rerouting wires to simplify the engine bay.Next year:Install Aluminum RadiatorInstall Aluminum Transmission CoolerMove the battery to the trunk
I like how you covered the grill opening. Maybe I should do that with mine. How do ya'll move the horns though?
In november of 2008, after the local car show season was over, and winter in PA was approaching, i decided it was time for the original motor to come out, and make room for the newer, older 66 motor! i think its safe to say that the engine compartment was in need of a refreshing.Next came the joys of redoing the engine compartment, first would be get rid of years of grease, grime, caulking, weather sealant, paint. At some point some one paint bombed the engine compartment, because i sand blasted it and discovered all the original stickers and labels, on the shock towers. To begin sandblasting, i would have to build a tent in my garage to control the dust, sand, and debris Notice the tarp zipper purchased at home depot. I use it to make a door in the plastic tarp to seal it off when i went inside to blast. I began sand blasting: I repainted the engine bay also, PPG low gloss black. Since i am doing a restomod, all the hardware bolts, (hinges, bracketry, supports, fender bolts, shock tower bolts, will all be the same as this shock tower bolt: ran some wires, and used blue loom on everything. Even used Goodyears, blue hoses, i think it would look good with the motor. new Export brace - Dropped right in, (everyone seems to complain about spreading the shock towers, and jacking the car up, i didn't have those problems). Monte Carlo bar to follow with chrome shock tower tops after suspension. [member]March – 09Motors In. When it was all said and done, it looked like this: [/member]
southern_boy. Why don't you post some pics of your current engine bay? Maybe then we can make a couple suggestions.
