Linux Mint 11 Rulez....
I've glanced at this while test fitting my GW frame connectors on my '67. The only solution i could come up with w/o cutting/welding was to use ovaled exh. pipe to go under the frame connector. It looks like 2 1/2" tubing ends up 1 3/4" high X 2 13/16", 3/4" more clearance compared to round piping but every little bit helps. If I do add it later I may just do dumps so I can remove the side exh. when not at the track, etc.Here's Dr.Gas but others make it also:http://www.drgas.com/oval_tubing.htmJon
