First off I have to say that I hate you Shaun :bird For years I could not decide between Global West and a factory suspension setup for my 1967 coupe. Well after the glowing reviews of the johnpro upgrade to his daughter's 1967 Mustang I decided on a Opentracker "roller" upgrade to the stock suspension. But noooo now you have to come out with something even better. Granted the only investment that I have made so far for the Opentracker is the Koni shocks. But I do need to clarify something. The wider tire size is the biggest reason that I was considering the Global West suspension. So a 245/255 on a 65-66 Mustang. What about a 67 Mustang? And what is the rim size that you were using?Also what size sway bar are you using? Can I assume that it is a factory bar?More questions to follow, but I want to start with the basics first.fd
That is very cool... I built my own tube chassis with QA1 Alumatic coil overs... not a performance shock at all. My plan was to upgrade at some point with adjustable shocks, but now seeing this I was wondering if you will be selling shocks seperately. Mine are 14.5 extended with 4" of shock travel, .69 motion ratio and 450# springs. Would your shocks work as a replacement?
Nice! Real cool Telemetry that you are showing. By chance the red gauge at the bottom, would that be Lateral acceleration? If so impressive, hitting over 1g.fd
Shaun,I noticed that the kit comes with upper and lower control arms, and the adjustable strut rod. I've already got your control arms and TCP's adjustable strut rod. Are you gonna offer a kit minus those pieces?
