Kat,Does the bottom of the air cleaner clear the linkage arm?
Looks good Kat. Did you verify that the throttle is pulling to wide open when floored? I have had some that there was a difference when the pedal was pushed vs the throttle actuated by hand under the hood. Also, the position may have to be changed when you install the carpet.
