Author Topic: Engine Refresh - What to do questions.  (Read 1161 times)
Offline janschutz
  • Corn Hauler
  • Allen, TX
    • John's Mustang Corral
« on: September, 20, 2010, 02:48:18 AM »
I have an A code 289 engine from my parts car that I want to put into my wife's stang.  It looks like it has been refreshes sotime in its past judging by the paint and other outer appearances. My first thought was just to drop it in.  I saw the engine run but it ran a little rough.  Since it had sat awhile The first thing I was looking at was the carburetor.
I have 3 carbs that I can use.  I would rebuild what ever one is best for this engine.  They are a Holley 570 Street Avenger, Edelbrock 1400, and the carb that was on the engine.  The Street Avenger has about 5000 mile on it, I used it on my 351W but it was too small.  The edelbrock was on my old 302 (it has sat for 2 years). What are y'alls thoughts?
I going to do a compression test later this morning. and pop the valve covers.
« Last Edit: September, 20, 2010, 02:51:48 AM by janschutz »
John L. Anschutz
2 68 Coupes
Offline Fast68back
Re: Engine Refresh - What to do questions.
« Reply #1 on: September, 20, 2010, 07:21:05 AM »
Stroke it...... I would pull the pan and a couple caps and check the bearings, if they look decent pull the valve covers and snoop around.
« Last Edit: September, 20, 2010, 07:24:46 AM by Fast68back »
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #2 on: September, 20, 2010, 10:20:37 AM »
I plan on selling the 2 carbs I do not need to help finance this engine.
I pulled the driver side valve cover and yikes!  :scar
Bent push rod, guess I better pull the intake to check it out.  Upe the cam is ok
Hard to tell with the out of focus picture but it looks like the valves have double springs. (I need a better camera)
For a 68, is the dark blue correct or the medium blue?  I know this is not the correct motor for the car but I just want it to look correct.
Offline 66gt350
  • Ah like me sum gunz...
« Reply #3 on: September, 20, 2010, 10:59:05 AM »
+1 on pulling a couple of the bearing caps.  When we parted out Moostang's '89 GT to put the engine in the fastback, the engine didn't have but a couple thousand miles on it, so I assumed that it would be good to go.  I had to swap pans, and I figured since the pan was off I'd look at a couple of the bearings just to see what they looked like.  A good thing that I did.  Every single bearing was wiped out.  When we put on the double roller timing chain, I didn't notice that it rubbed the block.  On the front of the block there are two smooth channels from the timing chain.  Those metal shavings, wiped out all the bearings, killed the pistons, and marred up the cylinder walls.  Luckily the cylinders weren't too bad, so I just honed them a bit.  If the engine wasn't already .030 over, I should have bored it out.  But I just impatient and wanted to get the car moving again.  I know that the engine won't last forever, but at least it will get me by until I build another motor.
I don't know if I'd stroke it.  You can go blind from doing that... :craz
-rob "Ricky Bobby"
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #4 on: September, 20, 2010, 11:56:40 AM »
Dark blue for motor color.
Offline fordrule
  • back into the world of mustangs..once I get back
« Reply #5 on: September, 20, 2010, 05:35:06 PM »
looks liek its going to be a fun refresh/rebuild
65 t code coupe.... 200ci/c4 whimbleton white...dubbed jo-jo 12 yrs ago.....
currently she has become project mayhem.. still having dreams of 8 cylinders..but currently living in 6 cylinder reality..
I wanna go fast....
Offline Starfury
  • My car HATES me
« Reply #6 on: September, 21, 2010, 05:26:59 AM »
I'd use the Holley, personally.  It's the right size, if a bit big, and it looks to be in good shape.  The Edelbrock is on the large side, and it's easier to tune an oversize holley than an oversize edelbrock.
What are you looking at for a budget?  With a bent pushrod, I wonder if the motor needs to be torn apart to inspect the pistons for valve interference.
Tad H.
'67 fastback
331 stroker
3sp m/t
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #7 on: September, 21, 2010, 05:36:45 AM »
I am hoping to finish the whole car with my 4K budget.  So I do not want to spend where I do not need to. The wife will need AC so I need to save enough for it.
I pulled the passenger side valve cover last night everything looked fine on that side.  I will pull the intake tonight to inspect under it.
Anyone know what model of carb the third one is (better to sell if I know what it is)?  I was also leaning on using the Holley.  The Edelbrock will be on ebay by tonight.  Got to get a few more funds.
Offline abrahamfh
  • Photophiliac.
  • keeping it old school
« Reply #8 on: September, 21, 2010, 01:33:35 PM »
Write up?
              MEET FRED!
Offline fordrule
« Reply #9 on: September, 21, 2010, 02:20:12 PM »
is it an autolite or a carter
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #10 on: September, 22, 2010, 03:24:41 AM »
Write up?
Pulled the intake and it was clean and ok.  I will pull out the lifter for the bent push rod to check the cam lobe.  I forgot to last night.
Offline abrahamfh
  • Photophiliac.
« Reply #11 on: September, 22, 2010, 08:32:45 AM »
Congrats, looks really clean. The 302 Fred had when I made the purchase looked like someone had BBQ'd and left all the used up charcoal under the intake.
Offline Coleman
  • AC Hit Man
  • Active Poster
  • Hell Ya, your on!
« Reply #12 on: September, 23, 2010, 05:41:31 PM »
Engine does look real clean.  You might have a winner!
1965 FB Custom
1966 Convertible Heidt's 351W AOD 3.40 Posi Salsa Red and Trailer Hitch!
1967 FB Anti-Eleanor Hot Rod 4.6 32V SC 6 Speed 3.80 Det Tru Trak
Offline Fast68back
« Reply #13 on: September, 24, 2010, 06:01:23 AM »
I still think you should stroke it...
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #14 on: September, 24, 2010, 06:04:16 AM »
This one is for my wife, I do not need her engine stroked ... ugh ... let's not go there!
Offline Kats66Pny
« Reply #15 on: September, 24, 2010, 07:25:29 AM »
Going to refrain myself from making any further comments about 'stroking it'  :ep
Offline Fast68back
« Reply #16 on: September, 24, 2010, 07:30:55 AM »
Oh, come on, its Friday and work is BORING....
Offline Kats66Pny
« Reply #17 on: September, 24, 2010, 08:04:19 AM »
Can't...this is an open forum!  :craz
Offline Fast68back
« Reply #18 on: September, 24, 2010, 08:05:50 AM »
 I can move the thread......     :admn
Offline silverblueBP
    • My 66 2+2
« Reply #19 on: September, 24, 2010, 09:43:17 AM »
"Now everybody have you heard
If you're in the game, then the stroke's the word
Don't take no rhythm, don't take no style
Got a thirst for killin', grab your vile...
You put your right hand out give a firm hand-shake
Talk to me about that one big break...
Spread your ear-pollution both far and wide...
Keep your contributions by your side and stroke me,
stroke me"
-Mark-
CarDomain
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #20 on: September, 30, 2010, 01:10:18 PM »
Got the new push rod,  There is a method to installing the push rod but I can not find my notes from when I did this a couple years ago.  I remember it was something like put the cylinder at TDC and tighten the rocker until you can not turn it with you fingers then give the nut a another 1/2 turn.  Can someone give the correct method?
I am also going to need some new spark plugs, wires and a new coil.  I will be using either a standard distributor with a Pertronixor a dual point with a Pertronix.  Any recommendations?
Offline Coleman
  • AC Hit Man
  • Active Poster
  • Hell Ya, your on!
« Reply #21 on: September, 30, 2010, 06:48:02 PM »
John, I have a new set of black plug wires you can have.  I'll drop them off at the "drop off area". :vic
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #22 on: September, 30, 2010, 09:23:18 PM »
Thanks Jerry
Offline fordrule
« Reply #23 on: October, 01, 2010, 04:49:16 AM »
here is a nice website dedicated to SBF...help with your build. a grassroots ford site...
http://sbftech.com/index.php
Offline janschutz
  • Corn Hauler
  • Allen, TX
« Reply #24 on: October, 03, 2010, 05:35:19 AM »
Had a little time Saturday afternoon, so I sand blasted the exhaust manifolds and painted the with Eastwood's Manifold paint.  Then I installed the diver's side along with new gaskets.
I still need to install the push rod.  Maybe Monday night since I work all day Sunday.
