First, the oil does not need draining to install the sending unit.
Nope. Yank that line out and replace the sender. Easy day.
I use VR-1 also but I think Kat has a roller cam 5.0 so zinc not as critical.
Well if nothing is going to pour out, then yeah I won't bother draining the oil. Of course maybe I should? Not really sure when is the last time Gertie had an oil change.
I usually run Wix 51515 filters
Normally, you need this extension for the sender to screw into.
Question about that extension... I was looking in my NPD catalog and there's 2 kinds.65-66 - 289, w/gauges, steel, 4.3" long extension, works on 67-73 as well67-73 - 289, 302, 351The sending unit you sent me is for a 66.. but I have a 302. Which extenstion should I get? Is the one for 302 going to fit the 66 sending unit I have?
