Author Topic: The ***"Official"*** StangFix Drag car  (Read 15232 times)
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
Re: The ***"Official"*** StangFix Drag car
« Reply #475 on: March, 20, 2011, 07:45:34 PM »
thanks Jon for all the help and more parts!
Offline fordrule
  • back into the world of mustangs..once I get back
« Reply #476 on: March, 27, 2011, 05:14:41 AM »
 :stu
hopefully we get some headroom made today on her
65 t code coupe.... 200ci/c4 whimbleton white...dubbed jo-jo 12 yrs ago.....
currently she has become project mayhem.. still having dreams of 8 cylinders..but currently living in 6 cylinder reality..
I wanna go fast....
Offline fordrule
« Reply #477 on: March, 27, 2011, 03:51:40 PM »
it  was a little bit too cold to work on her outside so we didnt roll her out..
first we used the rust inhibitor after I finished grinding and trying to get her all uniform smooth..started to apply the etching primer but only had the one can , so I covered all I could with it....got a lot done ..next is to finish with the self etching primer, then epoxy primer it all . Then finally shoot the grey.. but this is all going to happen after the 2 patches in the floor are patched up..
craig was doing the finishing touches on the 67 ranchero 302..stock 2V..looks damn good
Offline RapidRabbit
« Reply #478 on: March, 27, 2011, 05:00:35 PM »
Looking very good!
Sent from my HTC Liberty using Tapatalk
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #479 on: March, 27, 2011, 05:19:32 PM »
THANKS Joey! He did get a lot done. I have two small holes to fix. The passenger side is in a area with ribbed panel. I have a old scrap piece from my red car's original floor I can use to make the patch.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #480 on: March, 27, 2011, 05:31:36 PM »
this is my buddies 67 Ranchero that I have been rebuilding the engine and power steering parts for
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #481 on: April, 02, 2011, 04:49:41 PM »
worked on the floor this afternoon. cut the rust out and made a patch from the old floorboard.
Offline silverblueBP
    • My 66 2+2
« Reply #482 on: April, 02, 2011, 05:02:41 PM »
Nice work Craig, J been to your house lately?
-Mark-
CarDomain
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #483 on: April, 02, 2011, 05:07:14 PM »
J wouldn't put his name on my welds! but that's what grinders are for!
Offline fordrule
« Reply #484 on: April, 02, 2011, 06:37:22 PM »
good job craig..were you able to get more of the self etching primer and the epoxy primer? I am not sure how productive I am going to be with the arm in a cast
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #485 on: April, 02, 2011, 06:42:13 PM »
I got more etching primer and sprayed the whole inside. I did not have the funds to get the epoxy but I still have another hole to patch. No worries about helping. Get that arm better. I think the wife has plans for me tomorrow anyway.
Offline Jonk67
  • Yak, Yak, Yak
  • Smyrna, TN
« Reply #486 on: April, 02, 2011, 06:48:25 PM »
Joey was pretty productive at my house today with just one arm free.
We got 3 out of 4 trans lines bent which took the whole day as slow as I am. Thanks again for the help Joey.
Jon
Offline SELLERSRODSHOP
  • Nick Jr.
  • I smell smoke....
« Reply #487 on: April, 05, 2011, 10:05:41 AM »
better double check the tech sheets on the epoxy. most arent recommended over a self etching primer :no. either use the etch with 2k primer topcoat or use the epoxy over bare metal.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #488 on: April, 05, 2011, 01:18:52 PM »
thanks Steve, I used etching primer from Napa because I had bare metal (Napa recommended it). Do I need epoxy? I'm just going to spray it Ford Tractor grey from Tractor Supply.
« Last Edit: April, 05, 2011, 01:21:23 PM by tarafied1 »
Offline fordrule
« Reply #489 on: April, 05, 2011, 05:03:41 PM »
 :shee  bah sexy... dat der ford tractor grey
  • Nick Jr.
  • I smell smoke....
« Reply #490 on: April, 05, 2011, 08:32:56 PM »
since you have already used the etching primer, i wouldn't go to the expense of the epoxy. the selling point for epoxy is you can use it on bare metal & apply body filler over top of it. the etch does the same as far as biting into the metal. just scuff the etch with a scotchbrite pad & you can either apply a couple coats of filler primer or spray the topcoat.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #491 on: April, 06, 2011, 05:21:49 AM »
Thanks Steve!
Offline fordrule
« Reply #492 on: April, 06, 2011, 06:49:22 AM »
good news steve...might have the interior painted in no time if this weather holds up...might be warm enough to shoot
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #493 on: August, 23, 2011, 12:41:01 PM »
Well I haven't done much on the Drag car but collect more parts. Since the rear frame rails are tweaked pretty bad and I don't have the fabrication skills of J, I figured I would use the frame rails from the POS. This is about all that is left of the POS! I can drill out spot welds and reweld rosette welds. I would like to mini tub it while I am at it.
graverobberssheetmetal makes 2 1/4" wider inner wheel wells for $299.90 each
« Last Edit: August, 23, 2011, 12:56:01 PM by tarafied1 »
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #494 on: January, 07, 2012, 11:50:57 AM »
It was nice out today, in the 70's. Pretty nice for January. So I started drilling spot welds on the POS rear frame rails to start cleaning it up.
Offline lethal289
  • Steel Hoods Rule!
« Reply #495 on: January, 07, 2012, 03:15:50 PM »
nice to see you working on the old gal again.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #496 on: January, 07, 2012, 03:29:55 PM »
yes, life has gotten in the way. I hope to get back on it more. I would like to dedicate a panel to Sam or something
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
« Reply #497 on: January, 08, 2012, 08:31:15 PM »
Excellent idea!
Mike
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #498 on: January, 09, 2012, 03:49:36 PM »
Like others Sam contributed parts and advice, It would be cool to honor him in some way.
I did get the trunk floor and drop-off area cut off.
