Author Topic: Unisteer Power R&P on a 70, 351C  (Read 452 times)
Offline Larry G
« on: September, 01, 2010, 09:48:15 AM »
I'm in the process of installing the Unisteer power R&P on my 70, with a 351C engine.
I'm having a problem installing the p/s pump. I've talked to Unisteer and they said that they never had a 351c in the shop to design brackets for this engine. Their sending my big block brackets but I really don't think that help much.
If anyone has installed the pump on a 351c (I don't think the year matters) I'd appreciate the help and pictures would be great.
In the meantime I'll be trying to figure something out.
Thanks
1970 Mach1 Retirement Project
"Done but never Finished"
Offline mustangstofear
    • Mustangs To Fear
Re: Unisteer Power R&P on a 70, 351C
« Reply #1 on: September, 01, 2010, 03:13:29 PM »
why would you order a rack from them if they never did one on a Cleveland engine? Rich.
Offline Larry G
« Reply #2 on: September, 01, 2010, 04:14:28 PM »
I purchased the kit over 2 years ago and it was supposed to be for the 351 SB, I figured it would fit the 351C also but I was wrong.
Unisteer is sending me the brackets for the big block engines, not sure if that will help.
I've been working on trying to get something to work and I'm pretty close. Got the pump mounted, just have to make a bracket for the adjustment part, I know what I want just have to put it together. I should have it tomorrow.
The Cleveland is the engine that they don't make many parts for.
« Last Edit: September, 01, 2010, 04:16:40 PM by Larry G »
Offline Fast68back
« Reply #3 on: September, 02, 2010, 06:16:24 AM »
If you need a set of 302 brackets to try let me know, I tossed my pump in the corner and upgraded to a KRC pump and bracket from Shaun @ SorT
Offline Larry G
« Reply #4 on: September, 02, 2010, 06:32:37 AM »
Fast68Back,  Thanks for the offer but I don't think the 302 brackets will help. As mentioned before I have big block brackets coming and I really don't think those will work but I may be able to use part of them.
Would you happen to gave some pictures of your setup. I really don't want to pop for a new pump, yet, I've already had to order a new set of headers to fit the rack.
Offline Fast68back
« Reply #5 on: September, 02, 2010, 06:40:18 AM »
I changed because the pump that came with my kit had a low RPM whine when turning, the KRC has been really nice. They are not cheap, but I am much happier with the new setup. There are a bunch of pictures and links to KRC for different stuff in this thread:
http://www.stangfix.com/testforum/index.php/topic,5440.0.html
Offline Larry G
« Reply #6 on: September, 02, 2010, 11:17:28 AM »
Thanks for the link but I didn't see the Cleveland mentioned, do have a mounting for the Cleveland?
Offline Fast68back
« Reply #7 on: September, 02, 2010, 11:46:07 AM »
Is the 351/400 a cleveland based motor?
http://www.krcpower.com/catalog_i6511600.html?catId=353128
Offline Fast68back
« Reply #8 on: September, 02, 2010, 11:49:04 AM »
They also have a universal bracket
http://www.krcpower.com/catalog_i6511586.html
Offline Larry G
« Reply #9 on: September, 02, 2010, 12:34:17 PM »
Thanks a lot. I didn't go to their website to look for those brackets, if what I'm trying to do doesn't work out I may go that route.
Your car has AC doesn't it?
How does the system work with the AC?
Offline Fast68back
« Reply #10 on: September, 02, 2010, 12:51:49 PM »
Not yet..... The next car, A/C will be the first thing installed..
Offline Larry G
« Reply #11 on: September, 02, 2010, 02:27:43 PM »
Ok, My car is an AC car that I will have working next summer so I was just wondering how that pump and bracket work with AC.
Thanks again.
