Linux Mint 11 Rulez....
I was running the cars AC in my garage, I did have a power cat(squirrel cage fan) fan in front, and both electric fans came on(one fan would cycle). The air in the cabin wasn't being recirculated and it was really warm, or hot I should say. The gauges were 25-30/225-250 and the lines were pretty cold. The heater control valve I did help it to close a little better by hand, needs a little more adjustment to close with the control lever. The sightglass was clear of bubbles. I had it idling about 1500 rpm. I'm hoping that maybe once outside with air rushing into the condensor may help. the outside temp was about 97 and in the garage maybe hotter with the car running. I did evacuate the system for 45 minutes prior and held vacuum overnight, so that was good. So, what do you think Pete?
Am I the only Edelbrock owner here? lol:)First thing, move the accelerator pump linkage to the inner-most hole on the pump arm. If that doesn't work, you may need to replace the accelerator pump with a different, high volume pump.If it only does it while idling and not while driving, you may richen up the idle mix a bit (turn the idle mix screws in).
