I wish I could help Dne. I'm having my own carb problems and some of the guys I've talked to keep saying that Edelbrocks can be a big pain to tune and get running right. That's all I know about them.
I have an Edelbrock on mine. I don't know enough to give advice, but mine is a little hesitant on the throttle and I can't seem to get it to run smoothly either. currently running rich. I've given up. it's EFI time for me
EFI! Ok, I have to ask, but how much, ballpark?
Doing the work yourself.... and sourcing some nice used parts from a wrecked 5.0..... it could be done economically for ~$1000-1200. It can move up in cost quickly though if you start shopping for new parts on-line.
So do you have to use the AOD? I'm going to ask, and it's probably on the site, but was is involved?Gas tank mods?Electric fuel pump?as you said, electrical?eek!So for a set up like mine, it would just be a bolt on to my 289~ it's not that simple I know!
The stumble you describe is almost always related to accel pump issues. The rich mixture from the choke setting masks it when cold. Look in the venturis (with the engine OFF) and floor the throttle. You should see a stong stream of raw fuel shoot into both from venturis. If not, something is clogged. If that is OK, try giving it more pump shot as described on page 8 here:http://www.edelbrock.com/automotive_new/mc/carbs_acc/pdf/carb_owners_manual.pdfIf that doesn't work, there are other possibilites, but most of them will cause other drivability problems also.
I believe you A/C should be putting out closer to 40* or less unless your car was extremely warm running. Is that a Vintage Air unit?
It's an aftermarket unit for sure, Midlife might jump me if I say where I actually bought it from :shy.
My dear, you don't have to say another word! I'll be right over!
Dne',You may certainly state which AC system you installed. It's only in the "vendor evaluation" board where we try not to compare different companies/vendors. Within ALL other boards you can state "I bought a Holley carb" Or "I installed a Classic Air AC system" without any worries.Dave
