Author Topic: How do you install these  (Read 348 times)
Offline blown66
  • Active Poster
« on: August, 03, 2010, 11:36:52 PM »
I am installing new fuel line and rear brake line...I have bought a new bracket install kit for the lines.I have never installed this type of bracket.
First picture of the bracket kit
second picture is the bracket that I am not to sure how to install...Do you use a screw driver and push it in...Thanks
Glad to be a memeber. I was introduced here by 70/fastback.Thank you. I have a blown 66 fastback & 1971 Boss 351&2008 grabber orange GT vert, and for my daily driving when the weather is bad I have a 1999 ford f-150 stepside.I am retired.I am a photo
Offline silverblueBP
    • My 66 2+2
Re: How do you install these
« Reply #1 on: August, 04, 2010, 04:21:36 AM »
The pic is too small to see, but I believe those are the clips that you insert and then either pry apart to lock or pinch together to lock (can't remember).
-Mark-
CarDomain
Offline blue65coupe
  • Banned
  • where's my short bus
« Reply #2 on: August, 04, 2010, 04:38:47 AM »
Mark is correct.  To remove the old you take a screwdriver and pry the tabs apart.  This will close the retainer inside.  Insert the new and close the outer tabs with pliers.  This will spread the retainer insert.
Duane
Offline blown66
  • Active Poster
« Reply #3 on: August, 04, 2010, 07:25:50 AM »
Thank you very much    :pep
Offline blown66
  • Active Poster
« Reply #4 on: August, 04, 2010, 09:21:36 PM »
When installing the 3/8 fuel line do you secure the two in the tunnel first then the back part then the front? Also when you guys have installed the fuel lline do you reistall back in the original positons where the old brackets where at? I am just a little affraid if I install the lines that when I put the tranny in that the lines will enterfear.One more ? in the front where the fuel line comes across the frame does it come across where the edge is cut out? Again I thank you guys for you Knowledge...I will get a picture of that ?...Thanks God bless
1st pic..where line goes across frame
I am showing how long the area is where its cut out ..
Again Thanks
« Last Edit: August, 04, 2010, 11:55:57 PM by blown66 »
Offline blue65coupe
  • Banned
« Reply #5 on: August, 05, 2010, 05:33:15 AM »
You'll be fine with the transmission.  You have two or three clips in the tunnel to hold the line.  I can't really give you an accurate method as I re-ran mine with the car assembled and had to re-route it due to not being able to get a pre-bent line in.  As far as coming under the frame at the front you should have a couple rubber plugs in the engine compartment that will allow you to go through it.  I'll try and get a pic of my setup this evening.
Offline blown66
  • Active Poster
« Reply #6 on: August, 05, 2010, 11:40:23 AM »
Here are some random pictures of what me and my 6 year old grandson have been doing the last month or so..
1st picture of the splash sheild &caliper bracket on
splash sheild was hitting
not no more.a little grinding here and there
rotor and outerbearing
bearing installed
grandson who is 6 unbolting the ubolt bolts
Canon likes coming over and getting dirty and working oin the stang
right side done
canon taking the rear upper shock nut off
new fuel pump istalled..not sure but I hopeit will not leak when we get that far..that would SUCK!
pictures from under car..cleaned it with simple green and it got it down to the original primer
brake & fuel line kit
all the cleaning we did we did not find any rust...that is GOOOOOD.
