I completly replaced all components on my 70 coupe. I just realized it is setting much heigher than I think it should. Compaired to my 69 it is about 1 1/2 inches taller in the front.
After measuring several areas, I see the springs are compressing about 1/2 inch per coil less than the 69. The distance from ground to upper control arm is anout 1 1/2 inches longer on the 70.
The car had been begun restoration prior to me getting the car, but the front suspension apeard original. I pulled eveything off and it was apart for about 2 months. IDEAS????
