Bwahahahaha! He said "cheap" and "drag car" in the same sentence!Boy, I want whatever you're drinkin'.
yeah but I didn't say "Fast"
Two simple truths. No drag car is cheap and a slow drag car is no fun.
Keep in mind Craig, a race car is nothing more than a hole to through throw money into.but it sure is fun
I hear drum brakes are lighter and oldtime racers used them.
11.49 1/4-mile (7.35 1/8-mile) or quicker:-A 5-point minimum roll bar on a fixed roof car (t-tops okay as well if in place while racing) from 11.49 to 11.00 (7.00 1/8-mile). If the hardtop / t-top car has un-altered floors, firewall and frame rails (wheel tubs are okay), then the 5-point roll bar is good til 10.00 1/4 mile (6.40 1/8-mile). Convertibles require the 5-point bar from 13.49 (8.25 1/8-mile to 11.00 (7.00 1/8-mile). The rollbar must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. The roll bar can be bolted or welded to the floor, see diagram below for specs.Roll bar must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs.The 5-points are:Main hoop; 2 "down bars" (bars that go from the main hoop rearward to the trunk floor/hatch area. These can be straight or bent like a "package tray" style, search for photos); Welded crossbar for belts (can't be removable), see rulebook for exact location. Driver side door bar (can be a swing-out. Many put a passenger's side bar in as well (6-point) because it strengthens the car on both sides, but if you have subframe connectors the difference may be minimal).9.99 1/4-mile (6.39 1/8-mile)/ 135 mph or quicker:-Roll cage is required on all vehicles at 9.99 and quicker or any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs. Roll cage must also be certified by NHRA every 3 years and have a serialized sticker affixed prior to participation. This style of cage is good til 8.50 1/4-mile times, then a funny car style cage is required.
Even thou I have no extra parts, I would suggest a completely donated StangFix drag car. You do the work and parts come from anyone who can get them to you. Could be an interesting rig.
