Good lord, we have another "skyjacker" in our midst :amaz
Hmmmm, don't need a trade (having just bought JohnPro's '66) but prices are flexible......
That's a new term for me. I've always heard that the car looks like a stink bug.Ummm....Pete, you might need them for your "new" 66, I think that the back end is now held together with duct tape and baling wire :craz
It'd look even better with you wearing stiletto heels.
After doing some googling for rear suspension stuff - damn of insomnia :po I figured I might as well replace the shocks in the rear with the KYB GR-2. As for the leaf springs, I'm not really sure which ones to get. 4 leaf? 5 leaf? Mid eye? Want I would like to do is have the rear sit slightly higher than the front of the car. I think it just looks cooler. Edit: Ok I think I know what I need. I'm in love with look of AzPete's pony and it's what I want! :vic
I've got the 5 leaf "Grab-A-Track" standard eye springs and gas shocks from Mustangs Plus. My car sits at about stock rear height (the front is lowered). It is stiffer ride than stock but not bad at all. Having just drove over 3000 miles on the Hot Rod Power Tour with it on all kinds of road conditions I was pretty happy with it. Keep in mind though I had tools and luggage in it for a little extra weight. Even normal everyday driving though I have been pretty happy with the "Grab-A-Track" suspension parts...
If you're going total comfort, though, they're probably not the right spring.
They sat that way from the factory. I never cared for that look much either. At least level or real close. You might want to run 5-8 psi (or just enough to put a touch of lift to it) just to eliminate the real bouncy ride until you get the rear suspension completed.
Mine is a '67 and I installed 4 1/2 leaf Mideyes on the rear, if I wanted it to sit ~2" higher I would have gone with standard eye leafs. I would suggest the 4 or 4 1/2 leafs for you. The front has the 1" drop and 1" drop springs, I wanted my car level and tire tread just at the fender lip so it came out perfect so far. Jon
After thinking about it more, I do like that look but I want it slightly higher than yours, but not too much. So I guess I'm leaning towards the 4.5 leaf standard eye. I have the 1" drop springs in the front that were replaced last month. That would still give it a little more height in the back but not make it look like a "stink bug" right?
