Linux Mint 11 Rulez....
a storage facility where I won't have access to electricity
Thanks Pete, where do I pick up your RV? Jon
Use the generator to recharge the batteries of the sawzall?
Check the demand you will have plus the fused rating of you acc. plug. If your load is to much, going straight to the battery may be better. Always could take an extra car battery, use jumper cables to keep it charged, and run the inverter off of that. Might put a layer of protection for the vehicle.
I'm also on a time limit, it will be Sat. and the JY there that will buy the scrap closes at noon
I hope you're not expecting that 45 years since last installed 7.5 rearend to come off easily/quickly.So your plan is to load half of a 14x6' car onto a single axle 4x8' garden trailer..... and then remove the rearend.... and then fit the rearend onto the trailer with the car.... and then get the rearend to the junkyard by noon.Good luck.
