Author Topic: 1973 Mach 1 Starting  (Read 175 times)
Offline southern_boy
  • Breakin' bolts & bustin' wires. One at a time.
« on: May, 31, 2010, 08:25:30 PM »
Alright, so I put the wire back in the coil that I broke, and its not getting any spark at all now, so I was thinking, it ran when it was stock, so maybe if I put a stock coil on it to get it running again at least. that I could just put it back in place of the Mallory coil. Would that work???
Kevin Allen Bowers
Offline AzPete
  • Classic...less
Re: 1973 Mach 1 Starting
« Reply #1 on: June, 01, 2010, 04:48:40 AM »
try it and see.
USAF/Ret.
7 Previously owned..66-07
« Reply #2 on: June, 01, 2010, 03:59:50 PM »
No fire, at all, after changing the coil.
Offline AzPete
  • Classic...less
« Reply #3 on: June, 01, 2010, 04:00:56 PM »
Do you have power to the coil in both run and start?
« Reply #4 on: June, 01, 2010, 04:06:37 PM »
Eh, no idea. I had a spark before I pulled the old coil off to check it. Put it back on and no spark. Tried a new coil. No spark. Switched the wires to see if I had put them on wrong. and no spark. So could it be the Ballast Resistor?
