Linux Mint 11 Rulez....
Is the only difference in the bearing the outside diameter? In other words, is it safe to assume that the same axle (as long as spline count and axle tube length is the same) could be used in either style bearing housing? Theres enough information on the net to really confuse somebody about this. Ive exhausted multiple avenues in trying to find a 9 inch rear end for my car, I've done plenty of research, and im confident i could modify one to fit. I even think i could make a jig for checking trueness and straightening if necessary and also for reassembly. However, the housing i've sourced is a big bearing truck housing. I am curious if there is any problems i may run into. I plan to replace the 31 spline 5 x 5 truck axles with 31 spline correct length mustang axles. So when i replace the bearing with new, are the axle diameters the same length? Any tips, thoughts, ideas, links would be appreciated. Speak up if you have done anything like this. Thanks.
If you're shortening the axle anyway, though, you could probably use the tubes off your 8" rear and turn a big bearing rear into a small bearing rear. Then, if you wanted to just stay with a 28 spline you could re-use your 8" axles, or just buy new 31 small bearing axles.
Have you considered purchasing a "new" housing online? I picked one up for about $450 with with the correct spring pads and all. I looked about modifying the housing I had and it was going to be about the same price as the new one I ended up purchasing.
