Author Topic: Windshield wiper assembly maintenance  (Read 392 times)
Offline Dne'
« on: November, 02, 2008, 06:39:37 AM »
I was going to install my windshield wiper assembly, but the bushing where the wiper arms attach seem a little "dry" or not move freely as they should(The bushing going through the cowl). I guess after 40 years they may require a little attention.  How does one service these parts?  Am I clear about this question?
dne'
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
Re: Windshield wiper assembly maintenance
« Reply #1 on: November, 02, 2008, 09:56:47 AM »
I'm not sure I understand the question.
Do you mean the rotating assemblies seem dry or the mounting bushings?
Offline Dne'
« Reply #2 on: November, 02, 2008, 12:03:54 PM »
Yes, the rotating things! I just didn't know how to explain what they are! I was going to instal the wiper assembly, but if there is a way to lube them up, this would be the time to do it. I can always count on you Sluggo! :dance
Offline Sluggo
    • www.StangFix.com
« Reply #3 on: November, 02, 2008, 03:42:50 PM »
It's been a while since I put the 67 back together. I don't recall there being anything to do there other than cleaning and lubing them.
Offline cmayna
  • DILLIGARA ?
  • Menlo Park, Calif.
« Reply #4 on: November, 02, 2008, 07:10:20 PM »
+1    There is only so much anyone can do regarding this particular area.  Clean and lube whereever you can.
Offline joesgt281
  • Best of Both Worlds...
  • Yak, Yak, Yak
  • Mr. Horsepower
« Reply #5 on: November, 03, 2008, 06:30:39 AM »
+1 for the lube!
Offline Dne'
« Reply #6 on: November, 03, 2008, 07:00:31 AM »
There's no place to lube or grease fitting.  I'll do what I can.  Thank you for your advice all!  :notworthy:
Offline daveSanborn
« Reply #7 on: November, 03, 2008, 08:25:41 AM »
Dne,
Just as you should for the window regulators, door latches/hinges, etc., .... spray some White Lithium grease on the joints of the rotating assemblies.
Offline Dne'
« Reply #8 on: November, 03, 2008, 10:57:33 AM »
Thanks Dave! I knew you would pop in to save the day!!! :pep  :notworthy:
