Author Topic: Transmission decisions  (Read 959 times)
Offline RustyRed
Re: Transmission decisions
« Reply #25 on: May, 06, 2010, 08:04:53 PM »
I've never done the math but I'm probably getting about 10 mpg driving around here with all the lights, etc.
I don't know what the Stang would get on the freeway.
Might get better mileage if I ditched this Holley carb that is my main pita on the Mustang.  I've threatened to ditch it a couple of times and buy one of the Summit carbs.
My Explore in town gets about 14 ish...on the freeway on cruise control it gets much better gas mileage.
The problem is I work 5 to 10 minutes from the house and don't go to town very often so I don't spend much time on the freeway.
Coupes rule and Mark drools
Online Midlife
  • Intermittent Short
  • DOM
    • Midlife's home page
« Reply #26 on: May, 07, 2010, 12:54:53 AM »
Mid is optimistic.  If your 289 is bone stock with Ford tuning and you have 3.0:1 gears you might get 13 on highway.  You may get 15 around town.  You see these C4 trannys have a final gear ratio of 1:1, therefore you RPMs on the highway will be around 2500 at 70.  In Kalifornia where the speed limits are low you'll be OK, but out here where the speed limits are 75-80 you'll be able to watch the fuel gauge go down as you drive along.
I like and respect Mid, but I think he is wrong.  Also if you use the Kalifornia blend gas you will get lower mpg.
If you do anything to your 289 you will drop your mpg with the exception of an electronic ignition.  Oh, and what he didn't tell you is that his numbers are with a 2V carb.
Rock stock 289s with C4s are not loads of fun, they are fun, just not loads.
ALL IMHO....
Mel:
Not quite.  My numbers are based upon documentation on my website for Midlife, which is a 4V 289, bone stock.
Here's my website: http://midlife66.com/mpg.html
Panama City, FL
Offline RustyRed
« Reply #27 on: May, 07, 2010, 10:09:04 AM »
If you mean legally as in on the freeway...not to much.  I run up to car shows in Conroe on rare occasion but that's about it.
On the parkway here more locally where the speed limit is 45 mph...well I plead no knowledge of any wrong doing and exercise my fifth amendment rights thank you :-)
I do need to look at my exhaust as well.  Thinking maybe I'll keep saving up money and keep my ear to the ground for now.
Speaking of the Parkway...is this road not begging to punch it except for the pokey joes that get in front of you from time to time...
P.S. please notice there are no PT Cruisers leaving me in the dust  :10
« Last Edit: May, 07, 2010, 10:42:51 AM by RustyRed »
Offline AzPete
  • Classic...less
« Reply #28 on: May, 07, 2010, 10:32:36 AM »
I don't know.....that dark one 3 vehicles in front of you could be a PT. We will have to wait for a certain person to reply based on his expert knowledge of the rear view of a PT from any distance but close up......
USAF/Ret.
7 Previously owned..66-07
Offline RustyRed
« Reply #29 on: May, 07, 2010, 10:39:03 AM »
COO walked by in the hall when I read your reply and had to be wondering what the heck I was laughing so hard about.
Maybe we should create a new game called "spot the Cruiser"....any time you see one a good clip ahead of you snap a picture and see if certain people can pick it out  :beat
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #30 on: May, 07, 2010, 02:56:28 PM »
could this be a PT?  :ecit
Offline guruatbol
  • Grumpy Old Fart!
« Reply #31 on: May, 07, 2010, 09:17:29 PM »
Mel:
Sorry to disagree with your website.  I know it is on the web so it must be true...hehehehe...Anyway, my comments are from actual daily driving in SoCal and in the low desert in Cali.  Maybe it is all due to the Cali crap gas blend.  I don't know since one of them was in the early 80s.  I can tell you when I put 302 heads on the 66 I had a few years ago it seemed that the cheaper the gas the better it liked it.  Probably due to the larger chamber size and thus a lower compression.
Like I said I do respect you, just disagree this time.
Offline AzPete
  • Classic...less
« Reply #32 on: May, 08, 2010, 05:22:58 AM »
Ya all know that tire brand, inflation pressure and size will also change the results as will altitude, gas mix, and your off the stop acceleration. Don't forget the little things plus no two cars will be identical.
Offline RustyRed
« Reply #33 on: May, 13, 2010, 11:03:40 AM »
I've been kicking around the idea of buying an extra C4 and just rebuilding one myself.  Not sure how exactly to do it but the video link given above http://www.badshoeproductions.com/products.html#c4 looks like it would be helpful.
I am pretty much done with the Mustang for the most part anyway and have time for a project...might learn something in the process and could add the parts I want like the valve body from Summit racing, figure out how to put in a non-stock stall converter, etc, etc.
Anyone think it would be difficult to rebuild a C4?  I think it would be fun and a learning experience.
Figure if I pick up an extra for cheap then I can take my time rebuilding it and still have my car on the road while the tranny is in progress.
Offline 66gt350
  • Ah like me sum gunz...
« Reply #34 on: May, 13, 2010, 12:02:37 PM »
I've rebuilt a couple, and they're a piece of cake to rebuild.  I didn't have any videos, just the Haynes manual.
-rob "Ricky Bobby"
Offline 2ndgen
  • Loves the Sheep Organs
  • Active Poster
  • Waiting for parts...
« Reply #35 on: May, 13, 2010, 02:07:35 PM »
This is the easiest automatic to rebuild - my son (15 at the time) rebuilt his with minor supervision. I like the Haynes manual too - just be sure to be clean and well organized!
-Rory
"I'm not a Mustang expert, but I play one on the VMF StangFix"
69 Mach 1 - 393W - AOD w/4R70W internals - 3500 stall - 3.70 tru-trac - PS w/o air
multi-year rotisserie restoration
It now drives!
Offline RustyRed
« Reply #36 on: May, 13, 2010, 07:16:28 PM »
I think I will give it a try.
What I want to find first is a second transmission.  Figure that way I can take my time.  Nothing worse than getting in a hurry to get your car back on the road.  I've found hurry equals mistakes.
The one in the car doesn't have any slip or anything along those lines but the last time I am aware of that it was rebuilt was 15 years ago.  I could just change out a few parts like the valve body on it and call it a day but if I have a new motor might as well have a rebuilt tranny as well.  Besides with my luck I'd upgrade the existing one and it'd crap out on me.
Another benefit would be if I did have an issue with the rebuilt one I could put the existing one back in while I figure out my mistake.
After a trial period if all is well I could always sell off the one I have now or keep it for any future projects that might come along.
