Definitely need a 50oz balancer. Fluidampr is a pretty good brand.
When the engine was originally built it was balanced with 50oz parts. There had to be a reason. that's what I'll go back with.No choice on the oil pump. It's cratered.
and has 3,000 ft. lbs. of torque by 1500 RPM.
I'm callin BS.........
My bad. It's 3k by 1800 RPM. Read it and weep ...
I still don't see 3k, 300 maybe...
Where did you or someone get a 50 oz. 351w crank? That would REALLY limit your choices and make things much more expensive. As pointed out before, ALL 351w engines where 28 oz. imbalance.
PAW begins its quest for cubic inches with a 351W block bored and honed .060-inch oversize. The cylinder skirts are notched to clear the Chrysler 360ci small-block connecting rods. The 351W gets stroked a half-inch by fitting the block with a 400M crankshaft (the 400M is a tall-deck Cleveland). Keep in mind the 351W has a 3.50-inch stroke while the 400M has 4 inches of stroke. PAW takes a 400M crankshaft and removes the ridge not present in a 351W crankshaft. This gets the timing set to line up properly between the 351W block and 400M crank. The 400M crank is also machined to accept a longer Woodruff key, which keeps the harmonic balancer where it belongs. To marry the Chrysler 360 rods to the 400M crank, PAW machines the rod journals down from 2.311 inches to 2.124 inches. But there's more: PAW offset grinds the journals .125-inch to add even more stroke for a whopping 4.125 inches.Traditional 400M engines used a 28-ounce offset-balance harmonic balancer. Because we're changing the dynamics of the engine's rotating and reciprocating weight, PAW uses the late-model 50-ounce offset balancer to counterbalance the additional reciprocating weight.
From an article in mustangs and fords august 2000.
Ok. That makes a lot more sense. Are you going to stay with the 400M crank, or go with a modern, stroker one? Personally, I'd pony up the money for a modern SCAT or Probe crank/rods/pistons. In fact, if that's how your engine was built, I, personllay, would pony up $250 for a core charge and start with an '85/later, roller ready block.The PAW way of doing it was cool technology way back then. There's just SOOOO many better ways to do it, these days.
I'm going to have to refresh my stroker at the very least.Here's what I know I'm going to do for sure.Re-ring and bearings if conditions permit.Another new cam (obviously)New dizzy gearRebalance rotating assembly with new flywheel and balancer.
