Agree. I can see maybe a 1/4" difference but that is way the hell off. You won't have much pedal arm left if you adjust those pads. Do you have a spare brake pedal to compare to?
since the car was an auto, with power brakes, I'm adding a clutch pedal where there was none.I got a pedal with the kit
... I still have the pedal from the non-PB days, and it shares the same shaft as the clutch pedal, except when I had no clutch pedal, it had a dummy shaft. The longer PB brake pedal hangs from a much higher pivot point. ...
I think bending the clutch pedal is going to be the easiest thing for me to do as well...
